Originally Posted by Mrmiata
Do you also wash the hood blanket? Mines a little on the dirty side and was wondering a good way to clean it without destroying it.
~ i use the same method to clean the underside of the hood insulator.
start at the bottom with the soap and work your way up (do not get too close to the material - 12" away of so)... then the opposite... rinse from the top downward and once you are home... open the hood to allow the water to drain to the bottom of the insulator (perhaps leaving the hood up overnight for through drying). pretty simple with great results!
