To remove my 5 point Torx screw in the MAF I used a tamper flat screw driver. That's a flat bit with a notch in the centre to clear the pin.
It worked OK but made a bit of a mess of the socket.
I did the same thing, but I just took a standard flat bit that would work and ground out the center, perfect... until I broke it
