Old Feb 22, 2012 | 08:57 AM
JHM2K's Avatar
JHM2K
Default Re: Stock or Mesh Grille? Vote Away and Explain Why
Originally Posted by uknowhim21
When you buy that mesh grille does it leave a little gap at the bottom? Is that the issue? It seems like there is a gap at the bottom middle section on some of the crossfires that have it, but not on others.
That's the biggest complaint I've seen so far. If you have any color other than black, you can see the central core support bracket behind the grille. Also, you can look through the grille (from above) and see the remaining 3-4" of bumper fascia behind it, and the exposed slots for the OE grille's tabs.
I think coolx nailed it... it's not a great look, not a horrible look, it's just different. And it's all up to the personal tastes of the owner.
