Originally Posted by MikeR
You can try the MB alignment bolts, but they are only good for a couple of tenths of a degree... that may or may not be enough for your car. It was just barely enough for mine. The other, and best, option is to get the K-mac bushings and they will have no problem aligning the front end. They are a little spendy at about $380...
but cheaper than tires....
Here is a link to the K-mac set...
KMAC Mercedes Front Camber/Caster Kit 83-03 170/202/208 - Import Auto Performance
Holy crap! what size tires are you running? and what kind of wear were you seeing? my wife is going to flip out if this ends up costing 800+. I decide to try nitto Nex Gens I believe they are called. 141 a piece 11 bucks mounting and balancing per side. Had I known this I would have had the dealer that installed the wheels fix it.
thanks, chris
