Old Feb 22, 2012 | 05:52 PM
07bluezx14's Avatar
07bluezx14
Default Re: alignment questions????
Originally Posted by MikeR
yes, it sound like an alignment problem... is the car lowered? that will give you negative camber in front and back and wear out the insides of your tires....
the previous owner may have put the 215/35's on to get clearance from the nut on the upper inside of wheel well with the new rims..... you need to check that and see how wide a tire you can fit on those rims.... I would think you should be running a 225 or 235.... you may have to go to a 30 profile tire to get the clearance you need.....
The car isn't lowered, and I agree with the size. I mentioned the tires to the dealer after the first week, but he was unwilling to do anything about it, since I had put a few miles on them. Hell even the door says 220 or something. I kinda felt around behind the top inside part of the wheel, and it's close. If I used spacers the wheels might stick out past the fender. I'll have to take a closer look.
Thanks, chris
Wish it were a little warmer I would ride the bike while I figure all of this out.
I have to put a new tire on the back of it every year as well
