Old Feb 23, 2012 | 12:29 PM
BoilerUpXFire
Default Re: N/A 74mm Throttle Body Upgrade Guide
Originally Posted by dtinker
I have not had that problem ,that I know of. Haven't driven it alot since making the changes. You might try a "Throttle Reset". You may also want to inspect the throttle body to see if it is dirty. You may need to install an oil catch can if it is real dirty. Thinking about that change myself even though mine appears to stay clean.
I did a 'hard reset' with the negative battery terminal off for more than 30 minutes and have done my damn near daily resets with the key, no effect.
I cleaned the hell out of the TB before installing and there is no way that much grime could get in there that quickly when my 50K mile was relatively clean when it came out.
Thanks for the ideas though, always better to have multiple heads on the same issue...
is this with the OEM MAF sensor or the one that came with the larger MAF housing?
I swapped for the OEM sensor as indicated here...
