Old Feb 24, 2012 | 05:16 PM
ala_xfire
Default Re: 74mm Throttle Body, surging idle
Originally Posted by turbomar
Sounds like the TB acting up. Do what 180 says and revert back to 68mm TB and see what happens
I second that, and after you get the 74mm in your hand, If you are brave, you can remove the 4 or 5 clips that hold the plastic cover and look inside.
What you will find is a motor, 3 sets of nylon gears and a big return spring.
Push the throttle plate wide open and let it go - the spring should return it to idle position pretty fast.
If not - lube up the nylon gears with white lithium grease and try again.
If it still sticking, then deal with the source where you bought it for an exchange,
YOU DO NOT WANT TO TRY TO REMOVE THE THROTTLE PLATE AND SHAFT.
( Although the experts do when they bore one out )
