Old Feb 24, 2012 | 06:23 PM
onehundred80
Default Re: Windscreen wiper sensor keeps turn on
This is how to get to the windshield washer bottle.
Take it out and look at the connections and the level switch.
https://www.crossfireforum.org/forum...tml#post420447
Talk about coincidences, I answered this post and one week later I picked up the SRT and it had the exact same problem.
I took out the tank, cleaned out some slime that was in the bottle and on the sensor. I'm hoping the slime was jamming the float a little and causing it to flicker when the bottle was at the level just above the point where the light would come on and stay on. There is a delay built in to stop the light flickering if the float is bobbing up and down due to the cars motion.
After using some fluid the light stayed on permanently. I hope it is solved as it's a pain to remove the tank.
Edit, May 5 2012
Fix worked OK as light has not come on again.
