Quick note here on here for the crossfire to make it easier.
- Remove the wire from the wire loop that holds it.
- Bend the metal outward slightly that keeps getting in the way of you trying to get the socket on the Torx hearded bold (E8 socket)
- Remove the sensor and the bolt together (making sure you have slack on the wire)
- Then remove the wire.
It is a hell of a lot easier than trying to remove the wire clip prior to removing the sensor.
