Old Feb 26, 2012 | 12:41 PM
onehundred80
Default DTRL's and the Illumination Module
I have been wondering if it is possible to change the US Illumination Control Module to a DTRL module by adding a solenoid inside it.
My Canadian ICM (with DTRL) clicked when the car was put in gear, I know Rudy would probably know the answer, but what does anyone else know? Rudy are you there?
The unit that holds the fuses can be unclipped and removed and that is the part that has the part number on it. I am assuming that the other part is common to both and that the fuse part carries the solenoid. At one time I had both types of ICM's in my hand and considered taking them apart. I chickened out (Cluck Cluck) as the NA was for sale and I did not want to risk ruining the switch and have to buy another.
If memory serves me well I think Rudy took a ICM apart (TonyGG's) in the parking lot at Woodward in 2010.
If it can be modified it may be of benefit to some on this forum who want to have or remove the DTRL feature.
The ICM is simply plug and play, no changes to the wiring is involved.
