Old Feb 26, 2012 | 03:30 PM
James1549
Default Re: HELP: Car not starting. Not RCM or Crank Shaft Position sensor
Originally Posted by Kodebuster
If you suspect this, remove just the Neg cable from Battery, and connect Black jumper to loose Neg cable.
Hook the Red Pos jump to the Battery, as one would normally do.
If the car turns over normal, $hit can that Battery, and buy a new one...
I have done that procedure many times. But you must have a quality set of jumpers to make this work.
James
