Old Feb 26, 2012 | 05:54 PM
amx1397
Default Re: how things work on our car!
1. coin holder= behind the ash tray face plate
2. how to open hood 90 degree= push button (about eye level)as you push hood up,,to Close push buttom at top of rod ease hood down until it stops,,, then hood works normal again
3.Turn the passenger side airbag on/off by inserting the key in the side of the dash when the passenger door is open. Not quite hidden, but I'm sure there are people here that don't know about it.
4.After turning the key to "off" before your radio go's off,, hit the on ,,your radio will stay on for 30 Minutes.
5. Turn the Ignition key once and the car will auto crank until it starts, (automatic transmission cars only)
6.turn the headlights which to the left one click, it turns the right side lights front and rear on, two clicks, turns the left side parking lights on.
7.With your fingers on the headlight switch, put out, turned your fog lights on. But then turns them off, or with you and your headlights off they automatically go off.
8. in my roadster ( without the one-touch top switch ), if I jab the top switch twice in succession ( up or down ), both windows go up or down.
9. if I hold the automatic stick to the left, it does 5-4-3-2-1 so fast you pick your teeth out of the steering wheel ( can also over rev the engine ).
10. In the roadsters, center console locks when you lock your car. That way you can leave the top down and go to the beach without worrying about anyone opening the center console
