Old Feb 27, 2012 | 09:55 AM
a7x6kse6's Avatar
a7x6kse6
Default Re: 74mm Throttle Body, surging idle
Ok, so quick update. I checked the 74mm throttle body thread and realized I had used the wrong gasket, I got the correct one and installed it. Checked all connections and everything seems fine. Did a throttle reset after the new install and drove to work today. It seems to be a little better but again after about 20 minutes of driving it will rev up to about 1500 when I push in the clutch. Once I come to a complete stop it will slowly go down to 700 where it will idle beautifully. Also I do not know if this is relevant or not but when the engine revs on its own my ultra gauge shows the throttle % going up. I am going to check again for leaks when I get home from work and then swap to the old tb and maf if I can't find any. Is there an easy way to check for leaks besides just looking to check that all the hoses are connected?
