Old Feb 27, 2012 | 05:03 PM
Mike-in-Orange's Avatar
Mike-in-Orange
Default Re: Lowered cars... improve your ride...
Originally Posted by MikeR
The sway bar links are $150 shipped for 2 more buyers..... then it is $150 + $15 shipping...
The install is very easy and takes about 15 minutes per side..... I will do the other side of my car and do a write up and pics... you remove the wheel, take off one nut at the sway bar mount and a nut and bolt on the bottom at the control arm and then install the new link.... adjusting them to length before you install.... or I could just send them set-up 1" shorter than stock...
Forgive the questions as I'm not a suspension guru, but is there any need for an alignment after doing this? I know alignment parameters can be pretty tight so are there any issues if the length adjustment is off by a bit here - like 1/8 or 1/16 inch?
