auto zone 5 qts m1 0/40 and a m1 filter 32.99, they do not appear to carry the fleece filter, go to advance auto and get the puralator should have a made in germany on filter i with necessary o-rings, the extra o-ring is for replacing the 1 on dip stick , if u want to use the none fleece i think AZ has it, are get the filter for another car u may have.you will need 8.5 qts, but only put 8 in. Then check it after a while, add if low, Be sure and get a crush washer for a 14mm drain plug . I got all this at az today, use search button. There are a lot of photos and info about oil change. Have Fun
advance auto fleece part #L25277 puralator
