Old Feb 28, 2012 | 10:24 PM
live2drive's Avatar
live2drive
Default Re: Crossfire Turn Signal Mirrors!
Sorry, hit the wrong one.
Try this.
I'm actually hooking up my signals in the front of the car and I'd prefer not to run cables all the way back to the rear if I can help it. I found this post in another thread but I have 3 wires, one is a ground wire, one stays on a constant current and the other is for the current only sent when using the signal. I'm not exactly sure which wires get spliced to which wires and for the life of me I can't seem to disconnect the connector.
Originally Posted by FUBU
Side marker convert 2 indicator ONLY
Here is how I did it.
BEWARE: Always when doing electrical on cars take off the positive pole on the battery.
1. open up the front side markers
2. remove housing and lamp
3. cables (BROWN) and (RED AND GREY) on one side, and (BROWN) and (BLACK/GREY) on the other. See schematics and pictures.
4. the actual matter on how to do this the easiest way should be up to you. But simply, from the LEFT headlamp assembly, there is a connector. disconnect it.
5. Connect a cable to the BLACK/GREEN cable and simply connect it with the side marker.
6. Do the same on the RIGHT head lamp assembly where the cable is BLACK/WHITE and connect it to the other side marker. BEWARE: Funny enough there is a cable that is WHITE/BLACK. To decide which on it is, look for position "1" on the connector housing. the rubber around it is blue. should be top left when looking at the connections.
Voila!
HINT: Before taping up and start soldering and all, please check that everything is working properly.
If you solder, cut and twirl cables, use tape, I guess many ways of doing this is possible.
Also, I guess if you want the side markers to work as normal (illuminated at all times) AND be used as an indicator, try the above procedure BUT keep the original cables (RED/GREY) and (BLACK/GREY) but just connect the BLACK/WHITE and BLACK/GREEN aswell. It may work.
Regards,
FUBU
BTW. My 555th POST!
