Re: Heater wont turn off
You can't program it to continue running, but you can hit the recirc button and it will turn back on. It only will blow the fan at the 2 setting but it keeps the car kinda warm. It sounds like the button could be stuck or maybe you hit it accidentally after the ignition was turned off.
One thing I am not sure about is if the system works when the key is removed. I am pretty sure it works only in the ACC position but I could be wrong.
