Mike, I was hoping you would chime in. I need to try this stuff, but is it order online only like some of the other products, or is this 'over the counter' at any auto parts store?
Also, what are your thoughts on the final touch spray I mentioned above. I use it between washes and directly after a wash primarily, but it is great for anything I have tried it on...
Ultimate Wash & Wax Anywhere was picked up by all the major auto parts store chains, but Walmart is not carrying it at the moment. You should be able to find it locally.
The other product you mentioned, Last Touch, is from our Detailer Line so you won't typically find it at your local parts stores but it's great stuff. It has some glossing agents in it but no real protection. Very economical in that you can use it straight as a quick detailer or dilute it 1:1 with water for use as a clay lube. For routine removal of light dust, or right after a car wash and even while drying, it's a great bang for the buck product.
Something else you might want to try while drying is our Ultimate Quik Wax or, since you don't seem to mind ordering things online, D156 Synthetic Express Spray Wax is the Detailer Line equivalent to UQW but again, packaged in gallon containers, it's a bit more economical if you're going to use it regularly.
