Old Mar 1, 2012 | 02:39 PM
BoilerUpXFire
Default Re: 3 things you should use between washes
D156 Synthetic Express Spray Wax is the Detailer Line equivalent to UQW but again, packaged in gallon containers, it's a bit more economical if you're going to use it regularly.
First off, thanks as always for the great, prompt advice. There is a lot of misinformation floating around and it is nice to get a straight answer from someone in the know.
I will look into this product, should I expect a little more protection with this than with the last touch? I have to admit, regularly using that after every wash with a good 2 bucket system has made my car look amazing, but I could use a little protection...
You also mentioned using several microfiber towels to wipe down your car, and that's smart.
What size towels are you using? I use the meguire's ones that are pretty good size (~24"x18") and with ample turning of the cloth, I have never used more than 2 for the XF for a single coat, but I also only do this after washing or with very little dust, anything more and I wash.
I have to say I am very interested in the stuff that you add to water, wash and no rinse, what product would you recommend trying?
