Originally Posted by LCGI
I'm sorry to expose my ignorance of your terms...?
I've no idea what (R+M)/2 means - unless you defime values for R & M...
(did you see anything about this in the URL's)
PS> The 95 octane URL has a data sheet (PDF) and refers to RON...?
The most common type of octane rating worldwide is the
Research Octane Number (
RON). RON is determined by running the fuel through a specific test
engine with a variable
compression ratio under controlled conditions, and comparing these results with those for mixtures of isooctane and n-heptane.
There is another type of octane rating, called
Motor Octane Number (
MON), which is a better measure of how the fuel behaves when under load. MON testing uses a similar test engine to that used in RON testing, but with a preheated fuel mixture, a higher engine speed, and variable
ignition timing to further stress the fuel's knock resistance. Depending on the composition of the fuel, the MON of a modern gasoline will be about 8 to 10 points lower than the RON. Normally fuel specifications require both a minimum RON and a minimum MON.
In most countries (including all of
Europe and
Australia) the "headline" octane that would be shown on the pump is the RON, but in the
United States and some other countries the headline number is the average of the RON and the MON, sometimes called the
Anti-Knock Index (
AKI),
Road Octane Number (
RdON),
Pump Octane Number (
PON), or
(R+M)/2. Because of the 10 point difference noted above, this means that the octane in the United States will be about 4 to 5 points lower than the same fuel elsewhere: 87 octane fuel, the "normal" gasoline in the
US and
Canada, would be 91 in Europe.
It is possible for a fuel to have a RON greater than 100, because isooctane is not the most knock-resistant substance available. Racing fuels, straight
ethanol,
Avgas and
liquified petroleum gas (LPG) typically have octane ratings of 110 or significantly higher. Typical "octane booster"
additives include
tetra-ethyl lead and
toluene.
Higher octane ratings correlate to higher
activation energies. Activation energy is the amount of energy necessary to start a chemical reaction- since higher octane fuels have higher activation energies, it is less likely that a given compression ratio will cause knocking.
It might seem odd that fuels with higher octane ratings burn less easily, yet are popularly thought of as more
powerful. Using a fuel with a higher octane lets an engine be run at a higher compression ratio without having problems with knock. Compression is directly related to power (see
engine tuning), so engines that require higher octane usually deliver more power. Some high-performance engines are designed to operate with a compression ratio associated with high octane numbers, and thus demand high-octane gasoline. It should be noted that the power output of an engine also depends on the energy content of its fuel, which bears no simple relationship to the octane rating. A common myth amongst petrol consumers is that adding a higher octane fuel to a vehicle's engine will increase its performance and/or lessen its fuel consumption; this is mostly false—engines perform best when using fuel with the octane rating they were designed for and any increase in performance by using a fuel with a different octant rating is minimal. With that said the proper octane for a contemporary engine makes a huge difference vs. a lower then proper octane. Here is a white paper to support that:
http://dinancars.com/whitepapersFile.asp?ID=9
The octane rating was developed by the chemist
Russell Marker. The selection of n-
heptane as the zero point of the scale was due to the availability of very high purity n-heptane, not mixed with other
isomers of heptane or
octane, distilled from the
resin of the
Jeffrey Pine. Other sources of heptane produced from crude oil contain a mixture of different isomers with greatly differing ratings, which would not give a precise zero point.
So what all this means is that your 100 Octane RON fuel would be about 95 Octane in the US (R+M)/2. You only need a 92 (R+M)/2 rating so a fuel that is 96 or 97 RON would be correct for your Crossfire. The Shell Premium Unleaded with 95 RON would probably work just fine.
