Old Mar 4, 2012 | 01:38 PM
IBLUBYU's Avatar
IBLUBYU
Default Key won't remove when in PARK ... suggestions?
I fixed the sticky key problem last June, and have had no problems till now. When parking the car and putting the shift into "PARK", and turning the ignition off, the key won't come out. the car can be restarted and everything seems normal, till shutting down and placing in PARK. Key won't come out!
When stopping to park the car, I can shift to NEUTRAL, remove the key, and then shift into "PARK", Thru searching, I found reference to a cable from the ignition switch that may be the culprit, and may need adjustment(?). Anyone have any ideas or suggestions about this?
