Originally Posted by supmotard
Does the camber adjustments up front diminish tire clearance? After experimenting with diffrent spacers I opted to run without them. I have clearance (going to do some grinding for piece of mind) but if I go for a more aggressive camber......problems??
Thanks,
Mark
From what we found you cant really do much with the stock set-up. You need the camber bolt kit for the front to really adjust camber. I did not need to shave the top bolt above the tire but my father did with his hoosier's, I do plan on shaving mine just for the future.
I will let you know when we really get some camber up front if we have any issues
