Old Mar 7, 2012 | 11:35 AM
frankeyser's Avatar
frankeyser
Default Re: Pedal Replacement
I did an aftermarket set on my lsat base coupe, but it did not have the same pedals as the '04 and the limited models.
I removed the rubber around them and drilled the pedals, attached the aftermarket ones, pretty straightforward.
Thanks boiler, I was touching the back where the bads connect. And was guessing they were just rubber with metal glued perhaps to them. I did not want to try to pull them off unless I was certain they were not attached any other way.
