Old Mar 9, 2012 | 10:13 AM
JesseJamessrt6's Avatar
JesseJamessrt6
Default Re: longer wheel (lug) bolts
I measured the stock wheel bolt shank length at 40mm for both the front and rear. radusadirect on-line tool only offers packages of 20 each, you have to call to get packages of 10 each when ordering.
After I posted I did some more research.
I ended up getting H&R hub centric spacers and bolts for 5X112 with 66.56 bore;
2 each - 5mm DR 1055665 spacers for the front (ordered 10 each 12mmX1.5 tappered (conical) wheel bolts that are 5mm longer than my stock ones).
2 each - 20mm DRA 40556653 for the rear (includes wheel bolts to be bolted to hub and has new threads for stock wheel bolts). Just need to get tappered (conical) wheel bolts that are stock shank length for use with the rear 20mm spacers.
Does this all look right? I am second guessing myself about the 45mm shank length for the fronts and don't know what to order for the rears now (no spacers, should be 40mm if same as stock)?
I guess the question has to be answered; is the stock wheel wheel bolt shank depth the same as the aftermarket TSW wheel?
