Old Mar 10, 2012 | 06:03 PM
MikeR's Avatar
MikeR
Default Re: Lowered cars... improve your ride...
Jeremy, the sway bar link install is VERY easy. Plenty of room once you jack it up and take the wheels off. It only takes about 15 mins per side.
Cudaman, the factory camber struts/arms are NOT adjustable. To fix your negative camber you need to get a set of adjustable camber arms or the Kmac kit for the rear.
I measured the factory sway bar links off the car and from center to center of the top and bottom mounting holes they are ~7.8". I adjusted my links to 6 7/8" and installed. I chose this number as I measured the top mounting hole to the ground with the factory links at 16" and with no links installed the sway bar was at 15". I will be interested in seeing how Les does with his set at 7 1/4". Once installed you can adjust them to a different length very easily.
