Old Mar 11, 2012 | 04:55 PM
KDW4Him's Avatar
KDW4Him
Thumbs up Re: Fan/Buzzing sound top front of engine w/not running
My guess is the air pump contacts stuck in the RCM. But why it would continue with the ignition off is puzzling, but if the RCM is always live I guess that would answer it.
I think you nailed it. I didn't have the stuck on problem again however a few weeks later I got a P0140 code. I searched the boards & found the RCM issues and the poor ground issue right at the pump. Pulled the RCM and cleaned the contacts, re-soldered some suspect connections then cleaned the ground at the pump. All is OK so far! I suspect the sticking contact then became corroded or arc burned preventing the pump from coming on thus the engine code. It's really all a guess at this point but so far no light back on. Thank You to all who have posted pics & how to's!
