Old Mar 11, 2012 | 06:07 PM
IBLUBYU's Avatar
IBLUBYU
Default Re: Coolant Light Wont Go Off
Originally Posted by Howdconst1
I have a 06 Coupe. The loew coolant level light has been on since October (Car not driven much in winter). We replaced the coolant level probe in the tank. Light still will not go off. How do I tell if the fan motor is bad? I ran the car in garage for 15 minutes today and heat gage never went much above half way but fan did not go on.
Also, does anyone know of a good Cross fire mechanic in SW Michigan?
Thanks
Howdconst
You could pull the fan, and hook it up direct to battery just to test. If OK, you could have a bad fan controller. As far as a mechanic, don't know exactly where you are in SW Michigan, but it might be worth it to get it to Speedriven (Rudy) in Palatine, Illinois. He's the best! Driving the car when its cool/cold out is better than when its hot and you need the AC. Even if the fan/controller is bad, your car shouldn't heat up....... just sayin
