Old Dec 12, 2005 | 09:25 PM
HDDP's Avatar
HDDP
Default Re: Alignment issues with Eibach Pro-Kit??
Originally Posted by stryfox
I plan on getting myself an Eibach spring kit for the holidays.
Should I let the springs settle for a week or two to settle before taking it for alignment?
How far out of spec did the kit put you?
Thanks.
I can't answer that as the OEM alignment #'s were not done before I changed the springs and shocks... So, a baseline was never logged... I would let the car settle for at least a week, or more... You'll notice a 50% drop at first then the rest after a few weeks...
If I were to do it again, I would shave the rear spring pads to 50% of their original thickness while you have the springs out... Leave the fronts as is...
ANDREW, do you have any suggestions?
DG
