Old Mar 14, 2012 | 02:53 AM
onehundred80
Default Re: P2098 K299 No hair left
Originally Posted by aupaul
Ok guys I do not have an SRT6. I have a limited Roadster. But you folks are more into code scanning and logging. I have been fighting two problems. P2098 check engin light. And heat on all the time. Today my research of the p2098 shows a cause could be (k299) 02 1/2 Heater control circuit. WOW could this all be the same one problem?? As for the heat on all the time I can add ground to the lead on the heater control valve and heat goes away. Indicates heater control module.
P2098 I have changed all 4, 02 sensors. cleaned MAF and throttle body. Swapped fuel injectors from one bank to the other. and replaced crankshaft sensor. ANY IDEAS??? Help please......And THANKS
Do you mean cabin heat on all the time? That's what I read instead of sensor heaters. If so the answer is no, I guess.
