Thread: Ohm's question.
Old Mar 16, 2012 | 07:00 AM
maxcichon's Avatar
maxcichon
Default Re: Ohm's question.
Originally Posted by arejohn
It's a MONO amp. The two outputs are bridged internally and will provide the same outputs.
This is NOT a suitable amp for replacing the OEM. It is for low frequencies only <200hz (cycles per second) Audio range is 20 to 20k (20,000)
This is correct. Unless the OP wants this to run a pair of subs only-at 900 watts, and use the headunit to run the door speakers with ~ 15 watts?
Oh, yeah-that'll make the girls look on in admiration...
