Old Mar 16, 2012 | 12:50 PM
onehundred80
Default Re: SRT6 brakes, slide pins lubrication
Trying to put the St.Stl. brake lines on and I cannot move the fitting at the end of the rigid line on the body, it is really tight where it threads into the flexible hose. I have a ring wrench that is slotted to go over the line as I figured an open ended wrench would just roll the nut over.
Anyone have any ideas, I applied a little heat but no help.
Edit
Done it, clamped a vise grip over the split ring wrench so it did not spring open and went for it.
Another three to go.
Lotta help you all are, too busy working or what?
