SRT-6 TPS Issue
Hello,
Have an 05' Crossfire SRT-6 with 30K and having the following problem...I was cruising down the road then pressed on peddle to accelerate, but noticed a loose of power.
I took it home and hooked up a scanner, and it said TPS ( Throttle Position Sensor ).
I went to dealer and explained the above, and they couldn't find the part number and said the TPS was probably intergrated into the Throttle body and it would cost around 1K to get the part.
Is the TPS intergrated ( dealer could be wrong ) or a seperate part, where can I purchase it from, and how much would it cost.
Thanks for any info you can provide.
