Old Mar 16, 2012 | 01:54 PM
stevedask's Avatar
stevedask
Default Re: Crossfire Turn Signal Mirrors!
Originally Posted by live2drive
I'm actually hooking up my signals in the front of the car and I'd prefer not to run cables all the way back to the rear if I can help it. I found this post in another thread but I have 3 wires, one is a ground wire, one stays on a constant current and the other is for the current only sent when using the signal. I'm not exactly sure which wires get spliced to which wires and for the life of me I can't seem to disconnect the connector.
So did you figure out an easy way to wire the LED mirror indicators? Is there not a turn singal fuse in the box in engine compartment or drivers side fuse panel where you could tap the positive wire (turn singal) to it and ground the black and get the turn signals in teh mirrors powered?
I'm goign to attempt to add these aftermarket LED mirror indicators
http://www.ebay.ca/itm/ws/eBayISAPI....E:L:OC:CA:1123
to my mirrors so any advise on wiring is appreciated?
I will document and post the attempt to let everyone know if they work.
