Old Mar 17, 2012 | 01:24 PM
Thirteendog's Avatar
Thirteendog
Default Re: My Needswings manifold results
Originally Posted by ZAHANMA
Sounds like you need to talk to Jerry/Eurocharged about the TCU tune...no downshifting after that tune. It will hold the gear you choose.
I don't believe this is true, rather than holding the gear at the top of the RPM range it doesn't downshift unless you tell it to. So a recap and I'm sure Steve will chime in. You still don't have to upshift because it'll do it for you (at a slightly increased RPM level [6200 rpm I believe]) but you do have to downshift because it'll hold whatever gear you end up in.
