Re: Lowered cars... improve your ride...
Installed the sway bar end links on Saturday. Not a difficult install but a bit of a pita. Not a 15 minute install per side the first time you do it. On the other hand I was at a friends shop so trying to find tools and the rights size wrenches for everything (metric vs. standard) took a bit of time. I would also not recommend using a lift. I did and think it would have been faster using a jack.
There is an improved ride and improved handling. Everything just seems to work better - more like it was designed to. With the pretension the car was fighting itself.
I could have used a shorter center piece (I would have said rod but did not want to go there with this crowd). I reduced the end link to the smallest setting and still probably could have used another 1 - 1.5" of travel.
These are absolutely worth the money and effort. These plus the camber arms are making the rest of the stock components look bad.
