Old Mar 19, 2012 | 06:10 AM
  #54 (permalink)
hcarter's Avatar
hcarter
Default Re: Lowered cars... improve your ride...
Mike I just wanted to jump in here and say thanks again for this product , I will say with out a doubt this was in the top3 the best money spent on a mod to correct the handling of my car since lowering it. I have had some issues with the tires rubbing the inside of the wheel wells and have spent many hours and dollars to adjust and tweek the rear of my car , decieded to install them sunday morning ,the Install was straight forward ,and really simple got everything tightened back up and took the car out for a test drive to listen for noises and such ...first thing I noticed was the ride my car has never riddin this good since I first purchased it ,all of a sudden the rubbing issue is gone.and the rear of the car is planted and very predictable in the hard curves . its still hard to wrap my head around the fact that the pre-load on my rear sway bar was causing the rear to bind and ride hard , the shocks where obviously not being able to do their job at all ,but now thats a different story too ,,I adjusted them several times during the test run and imeadiatly noticed the difference in ride and handling each time I changed the firmness in the shiock the car responded to the setting ..,, I guess I'm very fortunate to finally find the right setup for my car and to have it performe better than I expected... the last and final mod I will be adding will be the 30mm front sway bar ,,and new Poly bushings on the rear.... Again Thanks for your input and parts you design ,guys like you and Woody and Rob have really help bring the cars to their true potiental ...... H&R 30mm Swaybar orderd , it will be on the car when I hit the Dragon ..
Howard.
