Old Mar 19, 2012 | 12:20 PM
IBLUBYU's Avatar
IBLUBYU
Default Re: Key won't remove when in PARK ... suggestions?
Howard, it seems there is an ignition cable lock that is connected to the shitfer lever assembly. Look on page 19-21, and read line 3 in the service manual. The cable may have broke or come loose.
James
Well .... James to the rescue again ..... I finally had a chance to drop the panel by the ignition as instructed in the "sticky key" procedure, and found that when I did the Sticky Key repair in June of last year, I evidently didn't securely fit the interlock cable to the ignition, and it had worked loose. After correctly securing the cable back onto the ignition, problem is solved. Thank you ...... Howard
