Old Mar 19, 2012 | 03:52 PM
onehundred80
Default Re: SRT6 brakes, slide pins lubrication
Job done, no squeal, pads free thats the good news. Bad news is the pedal is still low. Somehow this is not what I expected, it is like my 300 though. I will have to see another SRT Xfire and compare. The na seemed different in my memory, different set up though.
Used nearly all of two liters on the fluid change and bleeding, maybe I'll bleed them again. I used vacuum initially on each wheel and finished with a gravity drain. Next time I'll get a buddy to pump the pedal and try that.
The vacuum sucked air through the nipple thread, thats why I did the gravity to finish it up.
