Re: SRT6 brakes, slide pins lubrication
I just put the SRT brakes on my NA and had a soft pedal initially. While searching on google, I saw a post that recommends pumping the pedal until firm, then quickly crack and close each bleader starting at the one farthest away from the master cylinder and working to the closest. It is a two man job, but result was worth it. Good luck.
Mike
