Old Mar 20, 2012 | 09:41 PM
onehundred80
Default Re: Topsider, another use for it.
Totally cool, I now have two more uses for my topsider. First, I didn't know it could be used for bleeding brakes! Second, I see how it can remove bugs by holding a vacuum on a bug carcass. Thanks 180, you came through again!
As I was told the vacuum does not work too well on bleeding the brakes. It sucks air past the threads on the nipple. I did a preliminary bleed with the vacuum and then did a gravity bleed and later I had a buddy pump the pedal as I cracked the nipple.
A pressure bleed would be better than the vacuum method by far.
