Old Mar 21, 2012 | 02:41 PM
  #110 (permalink)
james1's Avatar
james1
Default Re: Battery Replacement
Hi,
I just now had to replace my original battery in my '04! I noticed a
change in hydometer readings last year and it finally gave up. It won't take a charge so I suspect it is sulfated the plates from not enough use.
Here's some updated info for "onehundred80" 's original info page as it
pretains to the Canadian Tire replacement battery.
The battery in the original report was listed as a "Eliminator"
(p/n)#10-4800-8. This number now is for a "Motomaster" battery; apparently the same unit as before but they brought in a new improved "Eliminator" with the (p/n) 10-4885-6 that has a higher CCA of 910 @ 32F / 760 @ 0 F and a
120 min reserve rating. The recycle tag shows it's from Exide.
It is an identical fit and look for the Varta , with two handles but is black body and top ; vent holes and cap retainer holes provided.
Canadian price was 129.99 plus taxes for the new "Eliminator" and 109.99 for the "Motomaster" (better prorating and warranty on the "Eliminator")
