Old Mar 21, 2012 | 02:47 PM
onehundred80
Default Re: Catch can with a catchy appearance
Originally Posted by alaxfire
Max was referring to the hoses, not the connections on the can, and musing about if there would be a discernible difference between the left and right valve cover vent hoses in regards to connecting them both to a tee that would then go to the single IN port on the can.......
Personally, I have the NW can with 3 ports, so I have no concerns.
I see that but the Tee would be subject to a pressure from the can. So the pressure at each cover outlet would be the same, the Tee would do what a two inlet can would do.
