Old Mar 21, 2012 | 03:36 PM
onehundred80
Default Re: SRT6 brakes, slide pins lubrication
Originally Posted by alaxfire
180, you didn't put any thoughts in my head, and I too was interested enough to read up on this.
My conclusion ?
1. rock hard with engine off = nothing wrong with master, lines or calipers.
2. Pedal drops to floor when engine is started leads me to believe the the ABS is bleeding off the pressure.
But then, I could be wrong ........
I knew someone would point out the most expensive part.
I was keeping that dark thought at the very back, back, back of my mind. Waaaay waaaaay back.
The oil goes in there but until it is activated it should not interfere by opening it's valves. It should not need to be bled as it remains sealed unless the valves are opened. But this car was like this when I got it, so I do not know the history. No lights are evident, no codes set. But I am sure you could loose a lot of oil in there if it was empty.
