Old Mar 21, 2012 | 03:42 PM
dtinker's Avatar
dtinker
Default Re: SRT6 brakes, slide pins lubrication
Maybe this ABS system has had a problem all along and has air trapped in it. Maybe a good run on a very wide road and actually engage the ABS. It should purge itself and the fluid would either be low and/or foamy. Either case I would bleed and refill, oh are you sure you are using the correct brake fluid?
