Old Mar 21, 2012 | 04:06 PM
onehundred80
Default Re: SRT6 brakes, slide pins lubrication
Originally Posted by dtinker
Maybe this ABS system has had a problem all along and has air trapped in it. Maybe a good run on a very wide road and actually engage the ABS. It should purge itself and the fluid would either be low and/or foamy. Either case I would bleed and refill, oh are you sure you are using the correct brake fluid?
Correct Fluid - Motul 600.
This should not be drained under normal circumstances though as it should remain sealed, but as you say who knows. I should check out the system with a few locks ups though.
