Old Mar 22, 2012 | 07:43 PM
onehundred80
Default Re: SRT-6 Liftgate Leak On Spoiler Mounting Plate
I took of the panel today and found that I had a pretty good seal all around. A bit light in the top right corner but still touching.It was not stuck too tightly and popped off OK, the caulk all stayed on the car side.
I now have to find a good adhesive backed seal that is not to wide. 1/8" thick x 1/8" or maybe 3/16" max. wide should be OK. If its too wide it takes too much pressure to clamp it down.
I found the closed cell foam and applied it a month or so ago. Today I tested it with the hose and there were no leaks.
Job done.
