Originally Posted by Mrmiata
Just bought some on ebay last night..Xentec slim digital ballast- been thinking about it for a while and decided it was time to pull the trigger. Got the 6000K 's - $32.52 shipped. Care to share your wireing experience in a little more detail?
The wiring diagram that they sent me showed 3 wires running from the ballast to the fuse box. They ballast actually only had 2 wires running from it, so what I did was take the male F-Disconnects that were wired to the 9006 plug that runs into the ballast, and inserted those into the stock bulb connector. The disconnects just happened to be exactly the same size the bulb connections, so it fit perfectly. I made sure to wrap the entire connection up with electrical tape and then slid it back into the headlight assembly to keep it as dry as possible. I've driven over 200 miles in the car now, with the lights on the entire time, and have not ran into any problems with the setup so far. I have been keeping a very close eye on it though, just to make sure it doesn't burn something up.
