Old Mar 23, 2012 | 10:08 PM
SNAKEWOLF's Avatar
SNAKEWOLF
Default Re: SRT6 brakes, slide pins lubrication
If the master is internally bypassing. then when constant pressure is held against the pedal it will stay rock hard. If you just release a little of the pressure then the pedal will go down or bypass. Just an idea may not be the problem. good luck
