Old Mar 24, 2012 | 01:52 PM
70GT6's Avatar
70GT6
Default Re: SRT6 brakes, slide pins lubrication
As per the instructions in the service manual, make sure your not pumping the brake pedal. (old school habit)
This could compress the air trapped in the system into tiny bubbles that will distribute throughout the system.
I used a filler reservior and just gravity feed each brake into a can.
Hope this helps you out..
I agree. During bleeding this ABS system pumping the pedal is a no no. I used the reservoir bottle and a vacuum system the hooks to the bleeder and it worked perfectly when I upgraded to the SS lines.
Gravity bleeding can be done but takes a long time is you have air far back in the system.
