Old Mar 24, 2012 | 10:31 PM
GraphiteGhost
Default Re: Lights start flashing for no reason.
Check the rear below the foam inserts under the tire repair kit/compressor. Sounds like you have water in the locking/pump module. If it is, it'll be at lease a new/used module and some drainage added to the bay area afterwards. The foam inserts come out only after the side panels and such are taken out. I hope its not whats wrong but from the description, it sounds like it. Good luck!
